I don't think that resistance reading is meaningful in general. It is really a function of the voltage your multimeter is using for its resistance measurement function, since the thermocouple will have a fixed voltage drop across it and does not have ohmic behaviorHi R!f@@. Thermocouples generate a DC voltage when heated. resistance check will read 1-7 ohms aprox.
I did not get this part.I'd use more than one LM35 - set them some distance from each other. If the readings are quite a bit different between the two, you may have a bad sensor.
by Aaron Carman
by Jeff Child
by Jake Hertz
by Jake Hertz
