For few reasons really.Why is it a problem for these processors to run hot?
I regularly run the CPU in my HTPC at 75°C to keep cooling requirements down. It hasn't crashed, yet. And it is an AMD 64-bit 2.8 GHz processor, but don't ask me to quote the model, as it was a freebie.
India, State- Maharashtra, City- Pune. Why?Which part of India ?
My current ATX is the replacement for my original ATX which died few months back. My case is from I-Ball & supply came along with the same. I'm really pissed off because of the lame quality they offered. On other forum too I received advice not to use ATX from I-Ball. The most important thing of any system-The power supply! is not worthy. I'll try to take some action soon.@android you should first get the power supply issues solved. Check the voltages with a multimiter and if you really have just 9V on a 12V rail change the power supply ASAP.
Not for weeks buddy! I ran it for couple of months(playing Assassin's Creed-Brotherhood+lot of internet usage). Lucky my core didn't fried.I am beginning to wonder the same thing. If you had it running at 80c for almost a week without any kind of thermal past to help dissipate the heat, there is a chance that you may have damaged something inside the processor.
I did exact same thing to assure that TIM has reached each corner(Don't worry I didn't put too much TIM).When you put your heat sink on you don't want to pull it off the CPU once you have pushed it down because that will create air pockets that can effect performance issues such as heat problems.
Appreciate thatI always hate having things that don't work right, It is so frustrating. Wish I could just go right over and help you trouble shoot it.
This is the one i got http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021My current ATX is the replacement for my original ATX which died few months back. My case is from I-Ball & supply came along with the same. I'm really pissed off because of the lame quality they offered. On other forum too I received advice not to use ATX from I-Ball. The most important thing of any system-The power supply! is not worthy. I'll try to take some action soon.
Exactly! I cleaned up pile of dust from there. My fingers gone black after cleaning that with brush. Fan performance improved dramatically.Hello,
The dust can collect between the fins of the cooler and block the airflow.
Bertus
Did same thing yesterday. Improvement!I had this problem with my overheating AMD processor, it would run for 5 minutes then crash Windows. I took out the heatsink and it was completely clogged with dust. I used a paint brush to get out the dust and it was then fine.
Run your cpu 15 degrees over max for a prolonged amount of time and see if the LAW applies to you.Typical semiconductor lifespans for a complex processor are >2,000,000 hours @ 25°C
The Arrhenius activation law approximates a halving in lifespan for every 10°C increase, so at least 62,000 hours (7 years) can be expected at 75°C.
However you probably have a point about the electrical characteristics... many complex processors are only rated to 105°C or 85°C (sometimes lower...)
I guess i shouldn't have answered the question that way.I've never "worn out" a processor by overclocking. By the time their expected life is up in a gaming machine (1 year, tops to keep up with increases in speed), That system is now a server, one of them is running from 2001 still, it only does mail.
The new AMD and Intel slow down their clock when they get hot as a fuse.
Video cards, on the other hand, I've gone through a lot. They aren't as robust as processors. I had a 9800GTX that lasted 3 weeks, even though I kept it under 100 deg C, nVidia replaced it, that replacement lasted 2 months, fried again, I upgraded, lasted 6 months... The 480s I have now have been going good for 6 months, but I'm pretty sure posting this will make one of them die soon.
by Jake Hertz
by Duane Benson
by Duane Benson
by Robert Keim
