AMD Processor over temp
Discussion in 'General Electronics Chat' started by @android, Feb 10, 2012.
  1. @android
    Dec 15, 2011
    178
    9
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. @android
    Dec 15, 2011
    178
    9
    Speed is 3.4GHz. No overclocking!!. No heavy loading.:(
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Did you assemble the PC yourself?
    If so did you use thermal grease between the CPU and cooler?
    If you forgot to use the thermal grease the cooling performance will be bad and lead to a much higher tamperature.
    Bertus
  5. @android
    Dec 15, 2011
    178
    9
    No. I didn't assemble pc myself. Last week for the first time I was trying to overclock my cpu and I noticed this high temperature issue. Actually few months back I had problem with my ATX supply. At that time, while replacing my ATX as a curious exercise I dismantled my CPU from chassis and did some cleaning and put it back without thermal paste(That was really lame!!:rolleyes:). Last week while reading something on overclocking I came to know about thermal paste then I immediately did the correcting action, applied thermal paste. FYI without thermal paste my cpu temp was reaching over 80C. Now it goes to above level. What is the exact issue??? Do I need to use another better quality thermal paste?
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Is it a standard cooler you are using?
    Is the CPU fan regulated or fixed?
    You might also have a look at this overclockers forum:
    http://www.overclock.net/f/
    Perhaps they have more concrete solutions.
    Bertus
  7. @android
    Dec 15, 2011
    178
    9
    Stock cooler that came with PIB(Processor In a Box). CPU fan setting is kept for high performance.
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Are the cooler and fan free of dust?
    Dust can give a low performance of the cooler and fan.
    Are the case fans free of dust also?
    Bertus
  9. luvv
    Member
    May 26, 2011
    186
    31
    I have the exact same proc. in one of my builds,awesome performance for the price.
    First thing i did was replace the stock cooler,notoriously loud fan...
    This is what i went w/ http://www.newegg.com/Product/Product.aspx?Item=N82E16835233081
    You have to have a full size case cause it's huuuge, but very effective
    Also suggest pick up some http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
    And use this guide for thermal paste applicationhttp://benchmarkreviews.com/index.p...sk=view&id=170&Itemid=38&limit=1&limitstart=5
    With this cooler and paste it idles a few degrees above room temp and maxes out around 48C
    If you still have issues i suggest you check out this forum http://www.techsupportforum.com/ i stalk it also :)
    Pic is my setup,i have the HHD pulled at the moment to use in another project so it's a little messy.
    Best of luck,
    -luvv-
    @android likes this.
  10. @android
    Dec 15, 2011
    178
    9
    Thanks buddy! I'll try to implement your suggestions asap.:)
  11. @android
    Dec 15, 2011
    178
    9
    I really don't know how to check that 'dust' issue:confused:. On the exterior it looks fine:p. And in case if it is full of dust how can I clean it up?? I can always try cleaning. By the ways that's what cause this mess-Cleaning the highly efficient thermal grease and running processor for this long without it. Fortunately my processor didn't fry.:D
  12. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I use a aerosol to blow out the dust, like Dust off 67 from kontakt chemie.
    http://www.soselectronic.com/?str=371&artnum=33205
    Hold the fan still when you are using the aerosol, as the fan may generate a voltage that can distroy other parts as it turns by the flow.
    The dust can collect between the fins of the cooler and block the airflow.
    Bertus
  13. luvv
    Member
    May 26, 2011
    186
    31
    You know, i just noticed you reside in India.
    So maybe one critical piece of info missing from your post.
    What is the air temp in the room w/ the PC?
    I have seen post regarding cooling pc in rooms w/ less the adequate AC.
    Most involved liquid,active(TEC) cooling..
    There is a possibility the readings are wrong, because the 965 has a max temp of 62c.
    At 7O+ c you should be experiencing shutdowns and general erratic behavior.
    What Mainboard are you using?
    It may need a bios update to read correctly .
  14. R!f@@
    Apr 2, 2009
    8,793
    771
    Clean all the dust by removing the sink.
    Use arctic silver heat sink compound and properly sit the heat sink.
    re-check by removing and observing that the compound has properly spread across the processor.
    If not spread then u need to to find the sink is not seated. If OK then re-apply compound and mount the sink.
  15. @android
    Dec 15, 2011
    178
    9
    Generally around 26/27C. But that may not be an issue.
    ASUS m4a88TDM-EVO
    It may need a bios update to read correctly.
    How to update BIOS?
  16. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I can not find the mentioned motherboard on the asus site.
    Are you sure of the numbers?
    Bertus
  17. @android
    Dec 15, 2011
    178
    9
  18. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Wich version of the phenom chip do you have?
    Code ( (Unknown Language)):
    1.
    2. Phenom IIX4 965 (HDZ965FBK4DGI),3.4GHz,140W,rev.C2,SocketAM3,Quad-Core   ALL
    3. 1003
    4.
    5.
    6. Phenom IIX4 965 (HDZ965FBK4DGM),3.4GHz,125W,rev.C3,SocketAM3,Quad-Core   ALL
    7. 1003
    8.
    The C2 version (140 Watt) will create more heat as the C3 version (125 Watt).
    The chip is supported from bios version 1003 and up.
    See this page for more info:
    http://www.asus.com/Motherboards/AMD_AM3/M4A88TDM/
    Under the tab download you will find drivers and manuals.
    Bertus
  19. @android
    Dec 15, 2011
    178
    9
    I suppose C3 because with HW monitor my processor power dissipation goes around 117-118W
  20. nigelwright7557
    May 10, 2008
    488
    71
    I had this problem with my overheating AMD processor, it would run for 5 minutes then crash Windows. I took out the heatsink and it was completely clogged with dust. I used a paint brush to get out the dust and it was then fine.
