Ambiguity regarding RMS output of inverter circuit...
AnalogKid
Joined Aug 1, 2013
11,056
Going to a full bridge is a more complex and expensive driving arrangement, but it reduces the primary current by 50% because it doubles the effective primary voltage. The relationship between the PWM signal and its equivalent analog signal are exactly the same. With the center-tapped primary you had a 12 Vpp PWM signal creating a 6 Vrms waveform. With full bridge drive you have a 24 Vpp PWM signal creating a 12 Vrms waveform.
ak
