Hi.
I'm trying to make an AM radio receiver circuit.
So I have my antenna connected to a tank and then an envelope detector like so (sorry I forgot the resistor/capacitor in parallel after the diode)
When I put my oscilloscope to see the output signal I see a bunch of noise. With or without the resistor/capacitor in parallel, the signal goes into the negative region, which it should not.
Why is this? I figured that the signal must be amplified before the diode because of the forward voltage of the diode.
Is this true? If so, do I put the amplifier in between the detector and tank circuit? Are there any good rf amplifier circuits that you can aware me of?
Thanks for the help.
