Ok , so then I am a little confused are standard AM radio stations broadcasting SSB or fully orignal AM (DSB with carrier)?
I read that DSB with carrier is just wasting alot of power and bandwidth since all the info is in one sideband and the carrier is the largest amount of power need of the 3 elements. So I thought AM radio stations where just broadcasting one sideband to be more efficient. Thought this was some FCC regulation thing ... maybe I am wrong but with TV thru the air NTSC and ATSC use 8VSB or some variation which is basically using SSB supressed carrier with half of the other side band... But of course TV broadcasting maybe be different since standard TV may have TV tuners geared to do product detection as their standards,...etc
If the professional stations and amatuer radio stations broadcast as SSB without carrier? I would think the standard AM receivers would have to have product detectors as opposed to the simple enevlope/diode detectors?
Curious a transmitter that broadcasts orignal AM modulation (i.e DSB with carrier ) if it can be recieved by SSB carrier supressed AM recevier?
I think this is true
Basically what I am trying to figure out is will product detectors detect both DSB (carrier or not carrier ) and SSB ( carrier or not carrier )
4 different conditions.
Where as enevlope/diode detectors could only detect 2 of the 4 SSB and DSB with carriers broadcasts.
Correct me if I am wrong!
