So, I'm working on a simple circuit that seems to be working so far, but is different enough from my past experience that I want to make sure I'm not doing anything wrong.
I've got an a-stable 555 timer, adjustable around 6-40 Hz, whose signal I want to connect to three separate outputs, and I want those three to be individually activated with 5v signals.
I've hooked the switchable activation signals (5VDC) to the bases of three nte2361 npn transistors. I've hooked the shared 555 output to the emitters of all 3 transistors, and I've hooked the three output connections to the collectors. The outputs connect to a separate circuit which supplies 3.3V on those lines and reads signal when they are grounded out. So, any time a 5V activation line is on at the base and the 555 signal is low (ground) the transistor is active and connects the output to ground through the 555.
In theory this all seems right to me, but it seems like I always see transistors controlled by their base, not their emitter. In this case, I'm kind of using both, but the emitter is the one changing constantly. Is there a reason not to do this, or is this fairly common and it's just my inexperience that makes it look strange?
Also, if I've got 3.3V at the collector and the emitter cycles between ground and 5V, will the reverse voltage condition created when the emitter is at 5V be a problem for the transistor? I was considering putting a diode between the 555 and the emitters to prevent current from going the wrong direction, but I'm not sure it's necessary, or even that it would do what I'm thinking in this scenario.
Thanks,
Eric
Thanks,
Eric
