Am I connecting the transistor right?
Discussion in 'The Projects Forum' started by david1234, Jun 9, 2014.
  1. david1234
    Nov 27, 2013
    81
    I'm using this transistor -
    Motorola 9648 EBCK
    (after a long search I have found that it's Motorola number is - 48-11043C07 ), but could not found any datasheet of it
    so I think I have connected it correctly like shown in the image
    please let me know if I'm right
    my problem is that if I connect to is a device that work on ~ 500-600mA
    it doesn't work , and I can see that he voltage on it is 7-8V
    the S of the transistor is connected to 12V .
    can someone help me find my mistake?
    maybe I need another transistor?
    Thanks,
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    Is it a FET or Bipolar Transistor? "EBC" is a big coincidence if it doesn't mean emitter, base, collector?
    Post a schematic and you may get more help.
  3. david1234
    Nov 27, 2013
    81
    this is the circuit
  4. simo_x
    Member
    Dec 23, 2010
    200
    6
    It seems you are using the transistor as a PMOS. Are you sure this is a PMOS ?
    With a multimeter you can check if it is a MOSFET or a BJT. ;)
  5. david1234
    Nov 27, 2013
    81
    really?
    how can I do this? I don't know how
  6. Dodgydave
    Jun 22, 2012
    5,172
    778
    Put your meter on Diode test, or Ohms and test between Base-Collector, or Base-Emitter.
  7. absf
    Dec 29, 2010
    1,493
    374
  8. shortbus
    Sep 30, 2009
    4,098
    1,698
  9. david1234
    Nov 27, 2013
    81
    I have check
    B and C -->I get ~20M
    B and E -->I get O.L.
  10. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,529
    The thumbnail in your OP shows notation for a FET, and is reversed for the common ones like a 2n7000 etc.
    S-G-D.
    Max.
  11. BobTPH
    Jun 5, 2013
    808
    121
    The diode check range should be reading in Volts.
    bob
  12. AnalogKid
    Aug 1, 2013
    4,711
    1,303
    My first thought about the marking is that this is a private-label or house-marked bipolar transistor of completely unknown type, manufactured in the 48th week of 1996, with pinout Emitter-Base-Collector. That is a direct conflict with the schematic, but a very common marking from that period. Diode-testing the left and center pins should confirm or deny.
    Why are the 555 timing components connected backwards?
    ak
