Hi everyone,
I just asked myself why in textbooks they always set up the polarity of the diode in AM envelope detector so that it always pick up the positive half of the AM modulated signal? why not the negative half? what's wrong with it?
and after a lot of thinking, i came to the conclusion that the negative half is nothing but a 180ْ phase-shifted version of the positive half.
and if we thought of the envelope of any half as a current signal, then the changes in the envelope current amplitude of the negative half will be the same as the changes in the envelope current amplitude of the positive half, but only it happens now in the opposite direction. So, if i transmitted a speech signal, and reversed the polarity of the diode at the receiver so that it could pick up now the negative half of the received AM signal, then what was previously a compression when the positive half was chosen, the speaker will produce it now as a rarefaction and what was a rarefaction will be a compression, but it will maintain the same amplitude changes. right?
Since our ears works somewhat like Fourier analyzers, they only feel change in frequency, but not in phase. So i think if i set up an experiment with the envelope detector diode connected in such a way so that it could pick up the negative half of the received AM modulated signal, then i believe i would hear an identical speech signal to the one i have just sent and i wouldn't be able to tell the difference between the two.
By the way, i have read this article about AM diode detector and i quote:
What're your thoughts about this?
http://www.radio-electronics.com/in...n/am-reception/diode-detector-demodulator.phpIf the detector is to be used only for detection it does not matter which half of the envelope is used, either will work equally well. Only when the detector is also used to supply the automatic gain control (AGC) circuitry will the polarity of the diode matter.
