In practice it's not as clear cut as this antenna is better than that antenna. It depends where you are and what you're doing.
Even for AM broadcast, sometimes my simple small plastic loop from the electronics shop
performs better.
AM broadcast is vertical polarity. back in the day it might have done to point a horizontal
wire at your local station being directional, but switch to one from one to the other
might also bring in a lot of unwanted noise along with the signal.
The horizontal wire might also result in echo of propagated signals (fading in and out)
depending where you are. The best one is the one that works.
The wire I put up here was indented for HF, but is currently also my best AM broadcast antenna.
Not a dipole.. it's grounded from the feedpoint. Unfortunately I don't get to clear the house as much as I'd like.
performs better.
