Aluminum house...
Discussion in 'Off-Topic' started by cmartinez, Jul 11, 2015.
  1. cmartinez
    Thread Starter AAC Fanatic!
    Jan 17, 2007
    3,698
    2,774
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    Hope he has a lightening rod and earth stake fitted !!:eek:
    Max.
  3. cmartinez
    Jan 17, 2007
    3,698
    2,774
    :D yeah... now that I think of it... talk about building a super-capacitor!
  4. #12
    Nov 30, 2010
    16,671
    7,318
    Not a bad idea for heat reflection in a place where the heat index is above 100 for every day in July. The bad part is, it won't last very long. I have an aluminum shed that was here when I moved in...in 1978. Lovely for not rusting! So I framed the inside with 2x4's, added 2 inch slabs of foam insulation, bolted it to the concrete, installed 60 amps of 240 VAC and a ton and a half air conditioner. Probably the best back yard shed ever! I can arrive in a deadly sweat, cool the place from 120F to 80F in the time it takes to eat a sandwich, and load the truck for the next job while cooling off.
    If all it took to do that was a roll of Reynolds Wrap, everybody would have a shiny house!
    Of course, government agents are combing the books to find a way to tax it or make it unlawful. I say, "Write a law that says every activity or absence of activity is taxable" and save the bother of taxing everything individually. Just don't tell the government it's really a Faraday cage. That is probably already on the books as a threat to National Security (the ability to avoid government surveillance while pooping).
    SgtWookie and cmartinez like this.
  5. cmartinez
    Jan 17, 2007
    3,698
    2,774
    I hadn't thought of that... I wonder how many reception bars this guy gets in his cell phone when he's inside...
  6. cmartinez
    Jan 17, 2007
    3,698
    2,774
    And also... I'm not so sure as for that thing making the house cooler... aluminum does reflect visible light, but I think it actually absorbs infrared
  7. #12
    Nov 30, 2010
    16,671
    7,318
    I just checked for cell phone reception. No difference. Five bars inside and out. My local wireless phone drops out when I go in the shed. I guess its wavelength is too long to sneak in through the cracks.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I fail to see why this would bother anyone. I suspect it is the same kind of idiots that like to be HOA officers.
    SgtWookie and #12 like this.
  9. wayneh
    Sep 9, 2010
    12,379
    3,234
    A layer of foil - probably much thinner - is a common component of the insulation installed during construction around here, on one side of the panels they slap over the sheathing and below the siding. I believe it's also the moisture barrier, but anyway it probably contributes a little to the R value.
    That house looks pretty darn cool, in my opinion. I doubt the trees like being wrapped.
  10. tom_s
    Member
    Jun 27, 2014
    287
    342
    they must have aliens next door
    SgtWookie, DerStrom8 and cmartinez like this.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    Not to mention lightning rods.
  12. Lestraveled
    May 19, 2014
    1,957
    1,217
    Here is a picture from Google maps before the aluminum foil. It was a nice house. The article said he used spray adhesive to attach the foil. I bet he will be evicted soon and probably sued for destruction of property.
  13. #12
    Nov 30, 2010
    16,671
    7,318
    As a denizen of that locale, I believe that is a private home, not subject to a HOA, but if he's a renter, he is in for a big surprise when he tries to remove that spray adhesive!
    SgtWookie, Lestraveled and nsaspook like this.
  14. Lestraveled
    May 19, 2014
    1,957
    1,217
    That is exactly what I am talking about.
  15. strantor
    Oct 3, 2010
    4,302
    1,989
    I wonder why he didn't do the roof.
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
    He might have a plan, then again...
  17. cmartinez
    Jan 17, 2007
    3,698
    2,774
    Well, that guy did it for ornamental reasons, but these guys did it for protective reasons:
  18. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Wrong materials. Beer cans are the way to go :cool:
  19. cmartinez
    Jan 17, 2007
    3,698
    2,774
    Wow... that's art... and there's no arguing about it...
  20. alfacliff
    Dec 13, 2013
    2,449
    428
    why not just get a trailer house? already aluminum.
