I've recently decided to build an automated aluminum can crusher. I would like to set this up in a small room off of my kitchen, so simplicity and quiet operation are my primary design objectives.
After much research, I've decided to avoid hydraulics/pneumatics. I don't want the noise of an air compressor or hydraulic pump in my house. This leaves me with two design options; an electric motor driving a slider crank mechanism or an electromechanical linear actuator.
I recently acquired (for free!) a linear actuator from a lift chair. It's the type of chair that raises the seat to assist disabled people with getting in and out of it. It's rated for about 300 lbs. and will easily crush a can (I've already crushed a few).
The actuator is an OKIN Betadrive and is rated at 24VDC @ 2.2A. The travel of the moving block is approx. 16 inches. I would like to use external limit switches to shorten the travel to a more usable 6 inches or so and utilize a proximity sensor to detect the presence of an aluminum can. Detection would start the automated crushing process and stop it when no more cans are present. A can chute will hold several cans so I can load the chute and walk away from it while it does it's thing.
Would my linear actuator be suitable for such an application? I haven't started building yet, so I'm still open to suggestions. Any help would be appreciated.
