Altium Designer 14 Component library error.
Discussion in 'General Electronics Chat' started by ashkarmalik, Sep 6, 2015.
  1. ashkarmalik
    Jul 1, 2012
    55
    I have Build a Component of a Micro controller in Altium designer and I placed it i Schematic But as soon as I place the component there are red zigzag lines all over the pins (100Pins) Why it is so,And Also I build a Multi part component i.e a Quad Nand Gate and same Problem arises in that too.
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Run the ERC and it will show you what the errors are. Or, you may be able to simply hover over the red lines and it will show you in the HUD.
    ashkarmalik likes this.
  3. ashkarmalik
    Jul 1, 2012
    55
    Thank you DerStorm8.
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Were you able to find the problem?
    It may be that the software thought some inputs or outputs were floating. Or, if some of the pins have the same designators, they would be underlined. The "Messages" dialog should show you what it things is wrong. If you don't see the "Messages" panel, go to the bottom right where it says "System", click, and check "Messages".
    Hope this helps!
    Matt
