Altitude and electrical installations
Discussion in 'Homework Help' started by Msinks, Jul 30, 2012.
  1. Msinks
    Mar 3, 2012
    22
    How does altitude affect the performance of a transformer? Your help will be greatly appreciated.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    What is the major difference in the environment of a transformer at sea level and a transformer at 4,000m (assume it's in a building and that the room temperature is the same in both places)?
  3. Msinks
    Mar 3, 2012
    22
    the difference should be the pressure.....i guess :rolleyes:
  4. #12
    Nov 30, 2010
    16,704
    7,351
    and pressure on a gas changes its______.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    And as the pressure drops, does the air get less dense or more dense?
    Take it to an extreme. What impact would it have on transformer performance if it were operated in a vacuum?
    Msinks likes this.
  6. Msinks
    Mar 3, 2012
    22
    Ah! i got it....#12 pressure on a gas changes its density. WBahn that is really an extreme! Am guessing it would overheat due to the absence of air. meaning a transformer would overheat at high altitudes....? cool!
  7. #12
    Nov 30, 2010
    16,704
    7,351
    No...warm :D
    This is a good method for a lot of problems. Set up a mental spectrum from way "this" to way "that" and when you realize what the extremes are you can settle somewhere in the middle with the right answer.
    Msinks likes this.
