Alternator Used as Motor
Discussion in 'The Projects Forum' started by salty9, Jun 9, 2009.
  1. salty9
    Jun 8, 2009
    7
    What power can be obtained from an automotive alternator when used as a motor?
  2. rvh002@gmail.com
    May 15, 2009
    118
    Your question is not clear, An alternator makes electricity by turning it. Now how do you want to turn it into a motor?
  3. Mike Mandaville
    May 27, 2009
    81
    My understanding is that an electric motor is essentially a generator which is used in reverse, and vice-versa. Whether or not this will work in each individual case depends upon the design of the machine. Generally speaking, this will work better for DC machines than for AC machines.
  4. rvh002@gmail.com
    May 15, 2009
    118
    An alternator is not an electric motor only, it has 3phase rectificating biult in. tHE OUTPUT IS THEREFORE DC (A REGULATOR IS ALSO PART OF THE OUTPUT CIRCIUT)
  5. salty9
    Jun 8, 2009
    7
