alternative to ICL7107
Discussion in 'General Electronics Chat' started by erice1984, Jun 13, 2007.
  1. erice1984
    Jun 9, 2007
    16
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Did you have a question about the part?
    hgmjr
  3. erice1984
    Jun 9, 2007
    16
    I guess myquestion would be is there an alternative part made by a different company, or maybe something with an Analog to Digital converter.
    Anyhow I am a certified automotive technician and I have a tank in the trunk for water/alchohol injection system, and the level sensor operates on 0-90 ohms, 0 being empty and 90 being full.
    Instead of using op amps, and a bargraph LED display I figure I could make use of the digital components and make something that reads 0-99% fluid levels instead of displaying the level in 1/4 incriments.
  4. lightingman
    Apr 19, 2007
    374
    22
    Hi....Very simple with a PIC Micro....I have got this system on my Mini Coopers twin tanks.....Give me a few days, and I wil work something out for you.....Daniel..
  5. erice1984
    Jun 9, 2007
    16
    Thanks Daniel,
    I have no experience with PIC, and I dont know any language to program those guys with.
    only languages I have messed around with is IRC, Java, HTML, and a little VB
    or the tools to flash with.
  6. lightingman
    Apr 19, 2007
    374
    22
    Don't wory !!!!I can do this with a PIC16F628, I can write the code program it for you, and send it to you....A couple of questions !! ........ do you want it with an lcd(back lit), or LED (red or green) display....If in an LCD, what else do you want it to display?.... (You have 2 x lines of 16 charaters to use)....Also are the sensor connections floating, or is one side connected to +V or ground?................Daniel.
  7. erice1984
    Jun 9, 2007
    16
    sensor has +5vdc supply and then the sensor wire coming back to the PCB ya know to measure voltage drop etc. then to ground. The sensor is basically jus a variable resistor 0-90 ohm range
    I am really thankful for what you are willing to do, I might add other stuff into it later like Flow for the W/A inj and stuff, maybe other novelty things like est. time I can drive the car before I run out of the mixture.
    I like doing this kind of stuff for hobby, my Dad is an electrical engineer and I am going to go to school for automotive engineering (basically mech eng)
    and learning how to program will not be hard, just time consuming.
    All I ask for is to help me stay pointed in the right direction because to me there are a lot of IC choices and I don't exactly know what or which ones are best for what I want. But the answer seems obvious it will have to be programmed.
    Wow, just looked at the datasheet for the PIC controller... thats a lot! and a lot of learning for me.
  8. lightingman
    Apr 19, 2007
    374
    22
    Hi..I did the thing last night, and to be honest it is only about 30 lines of code for the LCD version, and 120 lines of code for the LED version (3 digits 0 - 100%) .......I will sort all the details out over the weekend, and get them to you....Daniel.
  9. lightingman
    Apr 19, 2007
    374
    22
    Hi again...Just a bit more info:- are you saying that the sensor is connected as a potential divider I.E. +5v one end and ground the other, and the wiper as output, or is it just +5v one end and an open output.....Also, is the +5 volt supply to the sensor regulated?.....I made a little mistake as the 16F628 does not have A/D converters, I have used a 16F877.....Daniel.
  10. erice1984
    Jun 9, 2007
    16
  11. lightingman
    Apr 19, 2007
    374
    22
    Thanks.....That is the info that I needed.....Please P.M. me your details so that I can send you the stuff......Daniel.
  12. erice1984
    Jun 9, 2007
    16
    what do you use software wise for coding the PIC controllers?
  13. John Luciani
    Apr 3, 2007
    477
    Maxim makes the ICL7106/07
    (* jcl *)
  14. lightingman
    Apr 19, 2007
    374
    22
    O.K.......
    This is all done.....
    I have finished it now...... There is a complete unit on it's way to Eric......
    But this is how it tured out........
    Daniel.
  15. Shogun
    Jan 16, 2008
  16. Shogun
    Jan 16, 2008
    Nice approach.
    Can you email me code?
    Shogun
    imjimj@wowway.com
    Edit/Delete Message:)
  17. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    A bit late in the game, but you could use an LM3914 for that. One single LM3914 contains 10 comparator circuits to drive 10 LED segments, in either dot or bar mode. Of course, your input voltage would need to be a linear function in order to represent anything close to what your tank actually contains; and few of such indicators are (linear). Such containers are generally an irregular shape, and the voltage divider network (potentiometer) swings in an arc; the level indicator seems to stay on full for a LONG time, then drops rapidly through most of the range and slows to a crawl near empty.
    Scaling via a lookup table in the microcontroller would be one easy way to get around such nuisances.
  18. karthickefy
    Dec 7, 2008
    hi daniel can you please send me the code for pic 16f877 ,
    (water level controller)
    by
    karthick daniel
