Alternative to dual battery isolator?
Discussion in 'The Projects Forum' started by gimmick1, Nov 5, 2011.
Thread Status:
Not open for further replies.
  1. gimmick1
    Nov 5, 2011
    I am working on a trailer with a 12V battery and an electric-hydraulic brake actuator (pump).
    The charge wire from the truck powers up the brake actuator only and does not connect to the trailer battery for charging. The manufacturer wired the trailer this way to prevent the actuator from draining the battery when parked (.3A draw when actuator is energized)
    I wired two SPST relays on the trailer to split this hot wire (from the truck) and power up the actuator and also charge the trailer battery. This would keep the actuator from draining the trailer battery.
    However, I did not foresee that because I used the incoming wire for both the relay coil(87) and feed through(86) that once the relays were closed, my trailer battery would backfeed and prevent the relay from opening.
    I haven't figured out a way to resolve this problem without buying a dual battery isolator.
    Any ideas would be much appreciated
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
Thread Status:
