alternative to a d flipflop
Discussion in 'General Electronics Chat' started by vitroblue, May 15, 2013.
  1. vitroblue
    Nov 19, 2010
    hi
    i'm making an experiment with a 8 bit MCU
    i need two signals to turn on or off a device
    A and B
    so i placed them in two pins, lets say
    MCUPIN8 and MCUPIN7
    but after fooling around with the logic i came to the conclusion that
    B = A'
    which remind me of the flip flop D truth table
    so i don't really need to waste two pins, one would do, but how can i generate the complement signal?
    at first i though a npn transistor could help. i'll take the collector as A and the emitter as B and solved... but that's just too easy. would that really work?
    i know the flip flop D does exactly what i want, but i'm asking this because i dont want to add a new part number to the bill of materials, but rather work with what i already have. besides, flip-flop d needs a clk, so i'd still be wasting two pins (at least). i could use that free pin in something else...
    should i rather stay with the two pins?
    thanks
  2. Ron H
    Apr 14, 2005
    7,050
    657
    If you want to apply A and A' to two MCU inputs, then you don't really need two pins and two signals. You can apply A to a single pin, and invert that internally with software.
  3. ErnieM
    Apr 24, 2011
    7,440
    1,627
    Of course, since you already own a microcontroller, and you can't return individual pins, there's nothing wrong with just using the micro's pins.
    And since B = A' doesn't have any state information it's not a model of a flip flop.
    It is however a perfect model for a simple inverter.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    I think I misunderstood your question. Apparently you need complementary outputs. In that case, what Ernie said.
