Alternative Inverter for Induction Heater
Discussion in 'General Electronics Chat' started by ajrenzetti, Dec 22, 2010.
  1. ajrenzetti
    Dec 20, 2010
    40
    Its been a while now since ive decided to make an induction heater. I have had no success whatsoever using a half-bridge inverter. the mosfets,igbts, and even transisters never seemed to turn on when they were fed the signal and connected to the source, even when i used mosfet drivers and induction heater schematics submitted by others who have gotten it to work.
    I was wondering, since induction heaters use inverting sine waves in the work coil, if instead of using a half bridge or full bridge inverter, if i were to make the inverter from this circuit: http://ecelab.com/circuit-sine-wave-gen.htm The only difference would be adding a DC blocking capacitor at the output and making the op-amp from high power transistors like in this design: http://ecelab.com/op-amp-circuit.htm
    I also took a look at the circuits on this web page:
    http://www.tpub.com/neets/book9/35e.htm
    Would these circuits work as an alternative to the half bridge inverter used in induction heating?
  2. jaangalab
    Mar 28, 2010
    12
    hi frnds if u want make it u shoud need a circuit
    1st driver with CL, FEEDBACK etc and high power igbt or mosfet
    and tell me what pupose u want it
    thanks
  3. marshallf3
    Jul 26, 2010
    2,358
    201
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    Operational amplifiers are low-power linear circuits which have little in common with the sort of high power system you require. Scaling up an op-amp is not a sensible approach to this problem.
    You would probably be better advised to investigate why you have had no success with circuits which other people have used. Are you sure that you really have obtained valid tested designs?
  5. ajrenzetti
    Dec 20, 2010
    40
    they have all been valid designs. but ive recently come accross the zvs induction heater design, and it seems to work if i connect it to a dc-dc converter and not directly from my power supply.
