Alternating Current Measurement
Discussion in 'Physics' started by Ultimate[R], Nov 22, 2015.
  1. Ultimate[R]
    Nov 22, 2015
    Is there an ammeter that can measure average value of alternating current for half cycle?
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Generally speaking the answer is no. You can get meters that will measure the peak, and you can get meters that will measure the RMS (Root Mean Square). The meter you describe would need to sample the waveform for a half-cycle and integrate the samples to find the mean value. An impertinent question. Of what possible use is the mean value over half a cycle? You do know the average over a full cycle is zero -- right?
  3. MikeML
    Oct 2, 2009
    5,450
    1,066
    Most ballistic analog meters measure the "average" value of a half-wave rectified AC wave.
    Most cheap DMMs measure the "average" value of a half-wave rectified AC wave.
    My expensive Fluke DMM will measure the true RMS value of a half-wave rectified AC wave.
  4. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Not exactly what he wanted in my opinion. A half wave rectified input is at or near 0 volts for half a cycle which will of course lower the average. He wants the average of just the half cycle of interest. The TS/OP may have to clarify what it is exactly that he wants.
  5. Ultimate[R]
    Nov 22, 2015
    the thing is, my teacher asked me why we can't use normal ammeters for ac measurement, i told him that in our country where ac frequency is 50Hz the current will change its direction 100 times in 1 sec which is too much fast for a ammeter to measure, he slapped me hard(it really hurt) and said that is not a valid reason and said that the correct answer is that ammeter measure average current which is 0 for a whole cycle in ac.So i just had a burst of curiosity and wanted to know about the above. thank you for answering the question. Tell me one more thing, was my answer that bad that i had to get slapped?
  6. MikeML
    Oct 2, 2009
    5,450
    1,066
    Interesting teaching method...
    Here is an example...
    @Papabravo, I think I interpreted the question correctly...
  7. Papabravo
    Feb 24, 2006
    10,338
    1,850
    No, the slap was completely unjustified and unprofessional.
    You didn't need to put together the sim on my account. I knew what you were talking about.
    Sorry Mike I still think you are wrong in you interpretation, but who cares anyway? Certainly not me.
  8. Papabravo
    Feb 24, 2006
    10,338
    1,850
    BTW. The reason that we use the RMS measurement of a sine or cosine waveform is the RMS voltage times RMS current gives the same answer for power in a resistive load that integrating the waveforms over a single cycle gives. That is an enormous advantage in simplifying the calculation since the RMS value has a well known relationship to the peak value.
    Also BTW, had I been your teacher, I would have commended you for your insight and your intuition. Not every notion that we come up with is correct, but that is irrelevant. What is important is that you keep thinking and coming up with insightful notions. Then proceed to test them. That is the scientific method that we should revere.
  9. KeepItSimpleStupid
    Mar 4, 2014
    1,259
    222
    Meters are classified as
    1. Average responding, RMS reading
    2. TRMS (True RMS)
    Yep, they forgot to tell you that they precision rectify the AC and multiply it my a fudge factor. The fudge factor assumes a sine wave input and makes the meter read RMS.
    The RMS voltage is the equivalent amount of DC that would dissipate the sampe power across a fixed resistor.
    Both meters have limitations, particularly frequency response.
    Mathematically the average value of a sine wave is zero.
    Teach didn't not do a good job.
  10. WBahn
    Mar 31, 2012
    18,080
    4,917
    You should show your teacher that you can use a diode in series with a DC ammeter to make an AC ammeter. How does your teach claim that an AC ammeter is made?
    As others have pointed out, you have to make some assumptions because what you will be measuring is the average current of a half-wave rectified signal. But, given those assumptions, you can map that measurement back to other parameters of interest, such as RMS current.
  11. DickCappels
    Aug 21, 2008
    2,753
    665
    [QUOTE="Ultimate[R], post: 925411, member: 297950" (Some text removed for clarity)
    Tell me one more thing, was my answer that bad that i had to get slapped?[/QUOTE]
    No, your answer was pretty good. It is your teacher who was that bad.
    It seems that many teachers react poorly at exhibits of creativity.
  12. WBahn
    Mar 31, 2012
    18,080
    4,917
    No. It was a reasonable answer and has some validity to it. If the AC frequency were low enough you would be able to see the meter needle move back and forth (assuming it is of the centered-zero type, which most aren't) as it tracks the current throughout the cycle, allowing you to note the peaks.
    No answer made in good faith should result in punishment of any kind. Now, if you had been insolent or flippant, that MIGHT be a different story, but that seems highly unlikely in this case. In the U.S. (and I suspect elsewhere) the teacher would have been in big trouble for hitting a student regardless of the reason.
  13. Ultimate[R]
    Nov 22, 2015
    Well my teacher told the answer a day before and i didn't attend the lecture at that day so he was pissed off i guess.
    Physical punishment is banned in my school too but no one follows it strictly. Also my teacher is kind of dumb(i know its not my job to judge him) but once some guy asked him on what factors does a focal length of a lens depends on and he replied, on the distance of lens from the object and the image and i almost died after hearing that.
  14. wayneh
    Sep 9, 2010
    12,368
    3,224
    Reconsider that thinking. You are the consumer buying an education from him. You have every right to judge him, and in many school environments you would be asked to do exactly that, to rate your teachers on a handful of criteria. The ones that get low scores are soon gone. Sometimes we have to hold our tongues, but don't be afraid to seek superior teachers.
  15. gnuuser
    Jan 17, 2013
    13
    ammeter no (or at least none that I'm aware of)
    oscilloscope yes
    your teacher is a twit
    there is absolutely no reason to strike a student!
    if they cant answer the question then they are supposed to research for the correct answer!
    the best teacher is the one who uses the insights and questions to learn himself so he can pass it on to his students!
  16. KL7AJ
    Nov 4, 2008
    2,043
    292
    I believe an iron vane movement fills the bill.
  17. dl324
    Distinguished Member
    Mar 30, 2015
    3,375
    651
    Your teacher had no reason for slapping you and, if there were witnesses, should be reported for assault. He has no business being a teacher.
  18. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Had he made the mistake of slapping me, I just might have put him in the hospital.
  19. WBahn
    Mar 31, 2012
    18,080
    4,917
    You never know how that might turn out. I had a teacher (actually, I never took a class from him, just had a fair amount of incidental interaction with him) that went to break up a fight between a couple of the school's tough guys. I happened to see it because it was right outside his class room and I was on my way to class next door. One the students decided that no teacher was going to interfere with his need to put the other guy in his place, which is how I first found out that this diminutive guy was the state's reigning full-contact karate champion in his weight class. Needless to say, came as a surprise to the tough guys, too.
  20. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Well fortunately this particular proposition has never been put to the test. I think my reaction would be more instinctive than the result of careful consideration.
