alternating current circuit calculations
Discussion in 'General Electronics Chat' started by omaroski, Oct 17, 2008.
  1. omaroski
    Thread Starter Active Member
    Jun 19, 2008
    34
    sorry for the bad english but i'm from Italy.
    If, in a capacitive circuit, i calculate capacitive reactance (knowing generator frequency and condensor's capacitance) through the formula:
    Xc=1/2π*f*C
    and then, knowing the RMS voltage of the generator i calculate the current with ohm's law:
    I=V/Xc
    can i get the RMS value for current and is the right way of doing the calculation or there's any problems related to voltage and current being out of phase?
    Thank you, hope i explained it good
    Omar
  2. mik3
    Feb 4, 2008
    4,846
    63
    If the circuit does not include a resistor or other component in series or parallel with the capacitor then you can do it.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
  4. Ratch
    Mar 20, 2007
    1,068
    With the impedance formula, you mean.
    If you use the RMS voltage, you will get the RMS current. If the resistance is negligible, then the current will lead the voltage by almost 90 degrees. A negligible amount of energy will be dissipated by the capacitor. I don't know, is there a problem with the phase of the current to the voltage being 90 degrees?
    Ratch
