alternate MOSFET
Discussion in 'General Electronics Chat' started by Bear_2759, Nov 29, 2011.
  1. Bear_2759
    Thread Starter Active Member
    May 23, 2008
    120
    guys, wondering if a guru can tell me quickly what a N-channel alternate to the IRF7207 MOSFET is. :D
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    Spec the gate voltage, breakdown voltage, and ON resistance.
  3. jimkeith
    Oct 26, 2011
    539
    99
  4. Bear_2759
    May 23, 2008
    120
    champion!. thanks:D
  5. shortbus
    Sep 30, 2009
    4,095
    1,685
    @Bear-Thought you wanted a N-channel compliment/alternate to the original P-channel?
  6. JMac3108
    Aug 16, 2010
    349
    66
    For MOSFETs you need to consider the application before selecting an alternate. If the MOSFET is used in a switching application (as in a switching power supply) then you need to be concerned about the various capacitances because they will greatly affect the AC switching loss and the efficiency of the power supply. Rather than looking at all the capacitances, an easier parameter to check is the gate charge Qg. This is often used as a figure of merit when selecting MOSFETS for switching applications. Just make sure the one you select has a close or lower rating than the one you're replacing.
    The Ids (drain current) specification is not really all that useful. The limitation in a MOSFET as in all semiconductors is temperature. When designing with MOSFETs you would calculate the power disipated by the MOSFET (both DC conduction loss, and AC switching loss) then multiply this power by the thermal resistance of the MOSFET (deg C / watt) to determine the temperature rise of the part. You then add this to your maximum operating temperature and make sure it doesn't exceed the max junction temperature given on the MOSFET datasheet (typically 125 or 150C). A good rule of thumb is to always stay below 100C. If your calculations exceed this limit then you need a heatsink. So, when selecting an alternate MOSFET for an existing design, make sure the thermal resistance is comparable between the old and new part. Most of the time it will be close because this is mostly a function of the device package. Measure the temperature of the old MOSFET when the circuit is running, and compare this to a measurement of the new MOSFET to make sure all is good.
