altering a signal
Discussion in 'The Projects Forum' started by s3b4k, May 13, 2011.
  1. s3b4k
    Feb 15, 2010
    38
    I would like to alter a signal that is about a couple thousand samples long to alter using matlab. any suggestions which signal i should use?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. s3b4k
    Feb 15, 2010
    38
    yeah it is its because i didn't want to go off topic with programming and signals so i posted two posts in separate forums associated with the topics;)
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    You can make the signal as complicated or as simple as you wish.
    A good start would be a pure sinusoid of known amplitude and frequency with superimposed random noise.
