Alligator clips
Discussion in 'General Electronics Chat' started by Mazaag, Dec 3, 2007.
  1. Mazaag
    Thread Starter Senior Member
    Oct 23, 2004
    255
    Hey guys,
    Question on Alligator clips..
    If i'm running a signal at 500KHz, would the use of an alligator clip cable introduce any significant inductance? i'm sure it depends on the clip itself, but generally.. ?
  2. Ron H
    Apr 14, 2005
    7,050
    657
  3. Mazaag
    Oct 23, 2004
    255
    what about the clips themselves? say i have a relatively short wire (15 cm say), do the ridges of the clips introduce a significant inductance at 500khz? like, do the ridges count as a "loop" of wire?
  4. chuckey
    Jun 4, 2007
    75
    10
    while the frequency may be 500kHz, you don't say what the current is, what sort of circuit you are tapping into and finally what sort of accuracy you are after. If you are tapping extra capacitors in across a circuit of Q=500+, then the croc clips wil effect the resullts, if you are just coupling a signal generator into the input of an OP-amp then you can neglect the crock clips. It also depend if the clips are plated steel or plated brass.
    Frank
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  6. Ron H
    Apr 14, 2005
    7,050
    657
    The ridges are insignificant. The overall length of the alligator clip could be thought of as wire length. Capacitance might be an issue (probably not), depending on what sort of circuit you are connecting to. As Frank said, we need more info.
    15 cm of wire (is that the loop length?), plus maybe 5 cm for the length of two alligator small clips, would give you about 200nH of inductance. At 500kHz, that's about 0.6 ohms reactance. If you're talking about a 500kHz sine wave, or 500kHz bandwidth, then probably not a problem. If you have a 500kHz pulse waveform with fast rise times, 200nH will be significant.
