Allen Bradley SLC 5/04 flashing FLT light
Discussion in 'General Electronics Chat' started by mcgyvr, Aug 14, 2014.
  1. mcgyvr
    Thread Starter AAC Fanatic!
    Oct 15, 2009
    4,793
    976
    I have NO PLC experience..
    We have a conveyor that has an Allen Bradley SLC 5/04 PLC with a input and output module next to it.
    When you turn it on the FLT light flashes and the DH+ light flashes green every 3 seconds..
    The conveyor is not working..
    I don't have the program or the software.. And the company that built it is out of business..
    From what I've seen it seems it might have a hardware or memory problem (lost its program) which I'd guess just means I'm dead in the water..
    Anything I can do?
  2. shteii01
    Feb 19, 2010
    3,516
    515
    Have you downloaded the manual yet?
  3. shteii01
    Feb 19, 2010
    3,516
    515
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    do you have the software that came with the plc? the one you connect and go through the ladder logic with?
  5. inwo
    Nov 7, 2013
    2,435
    315
    There is a free version of sw available.
    Actually that's what I've been using.
    You may be able to clear fault if you can get on line with it.
  6. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    That is the Logix S/W. If you don't have the original ladder and do not have the Logix, then you are basically dead in the water, at best, you would need to restore the processor to run with no alarm and re-write the program.
    I suspect you have either lost the program, battery or processor fault.
    Max.
  7. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Not from Rockwell surely?
    Is it a bootleg ver?
    Max.
  8. mcgyvr
    Oct 15, 2009
    4,793
    976
    Yep.. don't have the ladder.. don't have Logix..
    All information I can see leads me to the same 3 issues..
    Dead in the water.. Off to find a new conveyor.. :)
  9. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Do you have anyone else's PLC that you use to replace it with?
    That is the S/W I have but the site does not mention it is free?
    The older version I have has a Key that requires removing and reloading in the other PC if needing it transportable.
    (there is a way around it) ;)
    Max.
  10. shteii01
    Feb 19, 2010
    3,516
    515
    My mistake. I thought that was download link. It is not, it just takes you to another website. I don't see any download links.
  11. inwo
    Nov 7, 2013
    2,435
    315
    Yes, from Rockwell.;):D
    Kind of busy today, I'll try to find the link.
    Oh wait it's running on this computer.:)
    RSLogix Micro Starter Lite
    A search should find a link.
  12. inwo
    Nov 7, 2013
    2,435
    315
    My old sw had the key on floppy. Was a pain to keep moving it. For a while I made copies of the disk for more keys.
    Now the Starter Lite does the older stuff that I use. And works on the new computers.
    My original micrologix sw was dos based.:eek:
  13. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    I don't see the ability for SLC500, just the 1000 series, on that link at least?
    Max.
  14. inwo
    Nov 7, 2013
    2,435
    315
    Most likely true.:( I would try to find someone to get online with it before giving up.
    Years ago I had one with a dead battery that recovered.
  15. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  16. inwo
    Nov 7, 2013
    2,435
    315
    My bad, Could be right! I haven't seen a SLC since I got the new sw.
  17. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Allen-Bradly/Rockwell has NEVER been cheap.
    They traditionally have used 3 party equipment and components, re-labeled them and charged higher!.
    Max.
  18. mcgyvr
    Oct 15, 2009
    4,793
    976
    "IF" I wanted I would use the "Click" PLC from Automation Direct.. BUT its not worth my time when I can get a new conveyor for $2500..
    Its just a 32" PC board conveyor for a selective soldering line.. No biggie..
  19. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Is there room to set it up and reconfigure, or shoe-horn in another PLC make at leisure, and package and store it as a spare?
    Just seems extreme but I know when time is of the essence.
    On a related note, I am constantly being contacted by owners of CNC equipment etc, that do not keep a copy of the MTB parameters or logic, many realize the hard way that without the correct parameters etc, the machine reverts to a big chunk of steel. :eek:
    Max.
  20. mcgyvr
    Oct 15, 2009
    4,793
    976
    Oh.. I will fix it.. Just don't feel like it this week.. So I got them to get another. :)
