All things are possible
Discussion in 'Off-Topic' started by freeminded, Jan 17, 2010.
  1. freeminded
    Jan 17, 2010
    In this universe nothing is impossible to an "open" mind.
    Those that say so, only say it is "impossible" so they can impose their own thinking upon those they wish to keep in bondage so as to be exploited.
    The reason for this most likely is greed or a sense of power or control.
    prab00, go on questioning the known. Continue to strive to make the unknown (or the impossible) known (or possible).
    It is people that take what others believe are impossible and make possible that are the geniuses and those with actual intelligence. It isn't what you know that makes you smart, it is what you do with what you know that makes you a genius.
    I for one hope more people start to disbelieve free energy is impossible. We need to break away from the bondage of Oil companies and energy conglomerates that wish to control and herd us like livestock for their own dysfunctional ideals.
    It is those people and the people who support them that have nothing to contribute to humanity, with their closed minded greed and exploitation. The same people that try to impose their idea of right and wrong and what is possible, as if they know everything. pfft.
    A wise man knows he knows not (in other words, knowing that you don't know everything is a sign of wisdom)
    I am pushing more of my friends and students into finding a way to make free energy not only practical but readily available to everyone freely.
    Knowledge is power, truth sets you free and neither can be obscured for long. It is an inevitability that is inescapable no matter how hard you try to deny it.
    Keep fighting the good fight, keep striving to accomplish the impossible.
    http://en.wikipedia.org/wiki/Wireless_energy_transfer
    The "electrodynamic inductive effect" or "resonant inductive coupling" has key implications in solving the main problem associated with non-resonant inductive coupling and electromagnetic radiation for wireless energy transfer; specifically, the dependence of efficiency on transmission distance.
    The "electrostatic induction effect" or "capacitive coupling" is a type of high field gradient or differential capacitance between two elevated electrodes over a conducting ground plane for wireless energy transmission involving high frequency alternating current potential differences transmitted between two plates or nodes. The electrostatic forces through natural media across a conductor situated in the changing magnetic flux can transfer energy to a receiving device (such as Tesla's wireless bulbs). Sometimes called "the Tesla effect" it is the application of a type of electrical displacement, i.e., the passage of electrical energy through space and matter, other than and in addition to the development of a potential across a conductor.
    Tesla stated,
    Instead of depending on [electrodynamic] induction at a distance to light the tube . . . [the] ideal way of lighting a hall or room would . . . be to produce such a condition in it that an illuminating device could be moved and put anywhere, and that it is lighted, no matter where it is put and without being electrically connected to anything. I have been able to produce such a condition by creating in the room a powerful, rapidly alternating electrostatic field. For this purpose I suspend a sheet of metal a distance from the ceiling on insulating cords and connect it to one terminal of the induction coil, the other terminal being preferably connected to the ground. Or else I suspend two sheets . . . each sheet being connected with one of the terminals of the coil, and their size being carefully determined. An exhausted tube may then be carried in the hand anywhere between the sheets or placed anywhere, even a certain distance beyond them; it remains always luminous.
    and
    “In some cases when small amounts of energy are required the high elevation of the terminals, and more particularly of the receiving-terminal D' may not be necessary, since, especially when the frequency of the currents is very high, a sufficient amount of energy may be collected at that terminal by electrostatic induction from the upper air strata, which are rendered conducting by the active terminal of the transmitter or through which the currents from the same are conveyed.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    So it would appear that a man with an "open" mind can ... Fly?
    Of course this means I can make gold out of lead by the application of that special rock?
    Or, at least start buying the junk I have to offer. I need suckers who can't think clearly, but can believe what a louder voice says.
    Golly, another drive-by load of garbage. Unless, of course, you have some evidence to demonstrate? We keep reminding people that extraordinary claims require extraordinary proof. Another assertion that "anything is possible" hardly constitutes diddly.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Without experimental verification, theory is useless. You might say this is the cornerstone of science. I think there may have been something to Tesla's wireless power broadcast, but without repeatability and verification my opinion is worthless.
    Not all things are possible, science is about the pursuit of what is. If you can't repeat an experiment then there is a good chance it can't be done. Scientific laws are as much about what doesn't work as well as what is.
  5. t06afre
    May 11, 2009
    5,939
    1,222
    The term "Free energy" is very misleading. As you can not take a small amount of energy, and use it to create a larger amount of energy. There are NO buts, maybe or if to this rule. People may say so but this can only categorized as scams, shames, and flim-flams.
    Hydro-electric power stations, wind-power stations etc. Is based on renewable energy sources. This is not the same as free energy.The energy source for the latter is the sun, which as a fact is burring very slowly up as we speak.
  6. studiot
    Nov 9, 2007
    5,005
    515
    This is the part of the OP that really worries me.
    In a 'free' world a man can be as eccentric as he likes, so long as he does not foist his eccentricities on others.
  7. maxpower097
    Feb 20, 2009
    795
    388
    Obviously your not friends with Wile E Coyote! :)
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No, but, thanks to the National Lampoon, I have the record of his suit against the Acme Corporation for defective products and misleading advertising.
  9. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    I suspect the OP is a returning troll from banland.
  10. RiJoRI
    Aug 15, 2007
    536
    26
    My preferred response to "anything is possible" is "Go dribble a football for ten minutes or so." -- That's an American football, that looks kinda like this: ()
    --Rich
  11. ELECTRONERD
    May 26, 2009
    1,146
    16
    I don't believe there is "free energy," but perhaps someone will prove me wrong. Think about it; the energy from the sun will eventually die out, as will all the other stars. But, where did all that energy origionally come from?
    Austin
  12. loosewire
    Apr 25, 2008
    1,584
    435
    I just made a post looking for a person,so i started going down
    your list. It was going good with all the personal names until it changed to
    company names, more company names what I suspected the man
    we are looking for this time is not there.Are you that self proclaimed
    --------. or just asking a question. Good luck
  13. loosewire
    Apr 25, 2008
    1,584
    435
    He a new member lets welcome him first. Wecome to A.A.C. where we
    respect members post. Maybe as a guest you read some opinions on
    certain subjects. So you must be tolerate of opinions of members.
    Welcome
  14. VoodooMojo
    Nov 28, 2009
    503
    53
    some minds are so "open" their brains fall out.
    welcome to AAC.
  15. Wendy
    Mar 24, 2008
    20,772
    2,540
    And God said, "Let there be Light.", and there was light.
    At some point, where there are no answers or even theories, faith has a place. Every man and woman has to pick that place for themselves (Contrary to what most organized religions think). That is mine.
  16. HarveyH42
    Jul 22, 2007
    425
    5
    Tesla's free energy wasn't free to produce, it was free for anyone to use, anywhere on earth. Energy still had to be pumped into the system. It's too bad, that he wasn't able to complete that project, it would have saved so much. Probably would be having this CO2 Global Warming controversy these days, although probably something similar. :)
    The 'impossible', was that the people producing the power, wouldn't be able to profit from it, directly from those that used it. You don't get rich, by giving anything a way, free. Consider the cost of your cell phone, compared to the amount you paid at the end of your contract... Some companies even give you a fancy new phone for 'free'. I've never owned a cellphone, no plans on getting one. I do occasionally read some of the advertisement I get through the mail, and can tell that there are a lot of hidden snags in the offers, that could be costly. Not to mention, I don't like paying for things, I seldom use.
  17. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yeah, I'm extremely paranoid about cell phone companies myself. I need one, but not very badly, so I get a pay as you go. $60 for the phone, and $100 / year for 1000 minutes.
  18. ELECTRONERD
    May 26, 2009
    1,146
    16
    Amen!!! ;)
  19. Paulo540
    Member
    Nov 23, 2009
    188
  20. VoodooMojo
    Nov 28, 2009
    503
    53
    Atom
    There is no evil in the atom; only in men's souls.
    It is odd that one of the keys to abundance should have been
    handed to civilation on a platter of destruction.
    Adlai Stevenson
