All amplifiers some sort of power amplfiers
Discussion in 'General Electronics Chat' started by gusmas, Sep 3, 2009.
  1. gusmas
    Thread Starter Active Member
    Sep 27, 2008
    239
    Guys is every amplifier some sort of power amplifier. and if not where can i see examples of none power amplifiers.
    thx
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    NO.
    There are a lot of different types of amplifiers.
    There are also LNA (low noise amplifiers) used in the RF techniques.
    There are pre-amplifiers, used for amplying teh signal of a microphone or MD element.
    Here is a link to a page of the EDUCYPEDIA on amplifiers:
    http://www.educypedia.be/electronics/amplifiers.htm
    There are also operational amplifiers (OPAMPS):
    http://www.educypedia.be/electronics/analogopamp.htm
    And there are instrumentation amplifiers:
    http://www.educypedia.be/electronics/Instrumentation.htm
    Greetings,
    Bertus
  3. gusmas
    Sep 27, 2008
    239
    I cnt undrstand , because a ampilifier either amplifies the input current or input voltage, and the formule for power is P=V * I. I thnk i have the concept wrong?
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    You're right, but different components act differently at different power levels. A circuit that has 1KW in and 500KW out is a lot different than one that takes 50µv in and ouput 500mv.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Ok, when you look at the difference between in and out you are right.
    But they speak of poweramplifiers when they can deliver a lot of power.
    A normal opamp is often called a low power amplifier.
    An amplifier that can drive for instance a speaker or motor, we can all them power amplifiers.
    It is how you look at the concept.
    Greetings,
    Bertus
  6. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    you could say that every amplifier is some sort of power amplifier. A typical application does indeed increase the signal strength, hence the 'power' of the signal.
    However, the circuit surrounding an amplifier may not be designed to strengthen, but rather modify the signal. Active filters are but one example. In these cases, the integration of the package is it's advantage, as opposed to it's 'amplifying' properties.
  7. mik3
    Feb 4, 2008
    4,846
    63
    Every amplifier amplifiers power. People gave names to some specific kinds of amplifiers because some amplify voltage in a greater degree than current and vice versa.
