I have a software application that plots waveforms that are defined by a sequence of floating point numbers (think of the old X Windows program xgraph and you understand it).
I'd like to enhance this program with the ability to detect "significant events". Mostly, I'd roughly define a "significant event" to be a part of the waveform that differs in amplitude significantly from its neighboring points. For example, a waveform that is all zeros except for one point that has an amplitude of 1 has a "significant event" where the 1 occurs.
I'd like to figure out an algorithm that could efficiently find these significant events. A naive approach that works well on "theoretical" waveforms is to subtract each point from its neighbor. This is a simple finite difference approximation to the derivative.
However, real world signals contain noise and as most of you know, differentiating a noisy signal leads to more noise.
Can any of you suggest some algorithms that might be useful to find these significant events? I know very little about signal processing.
The application is written in python and the numerical processing stuff uses numpy, an array-processing library written in C. I would like to use only numpy functions, as using a python for loop is way too inefficient, as the waveform data can involve millions of points.
