albatrooss5 help with wiring
albatross5
Joined Jan 20, 2011
I put together a solar power pump using a 40 watt solar panel connected to a 10 amp accumiltor (morningstar ) to a 12v 24AH Battery have no problems battery charging. The system has been working for months pressurise a garden watering system at 5 minutes per hour over 120 minutes for24 hours.
Untill the water tank ran dry only then did I know that the float switch was not working .
The 6.5 amp water pump to wire to 1amp reed float switch to 12v relay (teminals 30,87,85,86)
then to a toggle switch To a morningstar 10 amp accumilator load terminals .
