Alarm Siren & Relay Help
Discussion in 'General Electronics Chat' started by G4M8L3R08, Dec 27, 2014.
  1. G4M8L3R08
    Dec 27, 2014
    32
    Hi guys & gals,
    Im completely new here so I hope I don't break any rules the first time I post.....
    I currently have 2 properties at the moment which is proving a pain as one of them isn't in the best of areas.
    I have a Yale HSA6000 alarm system in the loft so I decided to fit it to the said property. It has one wireless siren which isn't the loudest if im honest. It runs on 4xD cell 1.5v batteries, the idea is not to set it off if you want to conserve the power. I do have a spare siren and empty siren housing which I would like to put together and run from the wireless one, with a separate battery inside of course.
    My question, could I use the siren output on the wireless alarm, connect it to a relay which would complete a second circuit and set off the second siren? the wireless siren is also programmed to stop in accordance with the LAW so would the relay disconnect when the siren stopped?
    Thanks in advance
  2. MrChips
    Oct 2, 2009
    12,625
    3,451
    In theory, yes, you can do as you said.
    The devil is in the details.
    You will have to find out what kind of signal, current and voltage is supplied to the siren. Then you will need a relay or a circuit to drive the relay that can be triggered from the siren signal.
  3. blocco a spirale
    Jun 18, 2008
    1,460
    370
    What do you mean by "the siren output on the wireless alarm" ? Is this a switched power feed to a self-contained siren or is it an audio signal that just drives a loudspeaker?
  4. G4M8L3R08
    Dec 27, 2014
    32
    It is a stand alone 6v siren, I popped the meter on just to make sure its 6v that is coming out. Would it be possible for someone to recommend some components or a quick circuit diagram please, ideally with the said relay from Maplin, I live local to one. As you can guess Im no electronics expert so my idea of how it would go is bellow, sorry for the poor paint effort.
  5. blocco a spirale
    Jun 18, 2008
    1,460
    370
    That looks like it should work but you should also add a 1N4001 diode across the relay coil with the band to the + side.
  6. MrChips
    Oct 2, 2009
    12,625
    3,451
  7. G4M8L3R08
    Dec 27, 2014
    32
  8. MrChips
    Oct 2, 2009
    12,625
    3,451
    When they say "change over contacts" I assume that to mean SPDT.
    Either relay would work. The first one I mentioned appears to have longer pins for you to wrap around a wire connection.
  9. G4M8L3R08
    Dec 27, 2014
    32
    Ok, so the primary siren is 6v but the secondary im fitting is 12v. Just to make sure iv got this right, I need a 6v relay which is going to be switched when the 0v becomes 6v which will close the circuit for the 12v siren. correct?
  10. blocco a spirale
    Jun 18, 2008
    1,460
    370
    Correct.
  11. G4M8L3R08
    Dec 27, 2014
    32
    Thanks very much
  12. G4M8L3R08
    Dec 27, 2014
    32
    One last question, if I were to run this from a PSU, how would I add a lead acid battery to take over if the power went out?, would it be as simple as connect a trickle charger to the battery and just spur from the joint?
  13. G4M8L3R08
    Dec 27, 2014
    32
    Could I also pick your brains again please, I am wanting to do the same for my other property and connect an additional siren to the existing wireless one. Once again its 6v 4xD cell but a bit more complicated. the output that goes to the sounder isnt the same, I have put the meter across it and its showing 14.26v AC when the siren is active and 0 when inactive, how would I go about doing this one?
  14. MaxHeadRoom
    Jul 18, 2013
    10,838
    2,512
    Use a small bridge rectifier on the signal followed by a solid state relay or Opto isolator to drive a 2n7000 fet to switch the siren.
    Max.
  15. BReeves
    Member
    Nov 24, 2012
    412
    64
    I would drive a transistor, 10K to base of a 2n9570 and let the transistor pull a relay in. Just another way to skin a cat but without depending on the first siren's ability to deliver much current.
  16. G4M8L3R08
    Dec 27, 2014
    32
    Could you build me a maplin part list and a basic wiring diagram please? would really appreciate it. I can pick the parts up first thing and get it all soldered up. I just want the relay to close a 12v circuit that will enable a standalone 12v siren and 12v red flashing led, then disconnect once the original siren once it stops (one thats currently showing 14vac).
    The existing siren thats running from 4xd cells at 6v I doubt will be supplying much current, also would rather not draw too much juice from the existing one since its only running on 4xd
    Thank you all for the replies
  17. MaxHeadRoom
    Jul 18, 2013
    10,838
    2,512
    What is the current for the 12v siren?
    Max.
  18. G4M8L3R08
    Dec 27, 2014
    32
    250ma maximum
  19. MaxHeadRoom
    Jul 18, 2013
    10,838
    2,512
    Something like this maybe.
    Max.
  20. G4M8L3R08
    Dec 27, 2014
    32
    Would you be able to tell me exactly what I need from maplin please. sorry for being a pain
