Okay, I am in need of assistance in getting a fob system to work with my building alarm. What I have is a keyless entry fob on the outside and inside of the door. It is currently set up so that if the door is opened the alarm goes off, regardless if you swipe your fob or not. What I need to do is this:
Swipe fob and it closes the alarm switch so it doesn't go off when the door is opened. But I need this alarm switch closed until the door is closed than the alarm would go off again if someone who doesn't have fob access opens the door. The door is not lockable as it has an emergency exit push bar.
I hope I haven't confused anyone.
Thanks in advance.
Thanks in advance.
