Airsoft Game Timer Idea
Discussion in 'The Projects Forum' started by def3kt, Sep 27, 2008.
  1. def3kt
    Sep 27, 2008
    Hey folks,
    I'm completely new to this, but I had an idea I wanted to implement as part of my airsoft milsims. The idea is loosely based on multiplayer gameplay from Call of Duty 4, so it's not really all mine.
    The gist of what I want to build is this:
    To activate the primary countdown timer a player has to hold down a switch to begin a secondary countdown timer. When the secondary timer reaches zero, the primary timer is activated and begins counting down from a programable time. If the player releases the switch, the secondary timer stops counting and resets.
    I also want another switch that activates the secondary timer. However, when this timer reaches zero the primary timer stops counting down and resets to it's initial time.
    Hopefully this makes some sense and you can help me get started on this.
  2. def3kt
    Sep 27, 2008
    The search engine is only as good as the searchers vocabulary.
