Airplay on a USB size stick
Discussion in 'The Projects Forum' started by MatG, Nov 4, 2012.
  1. MatG
    Nov 4, 2012
    I'd like to make a USB powered device that can act as an Airplay receiver that plugd into my TV via HDMI so I can stream files from my iPad or iPhone. Think of it as a very cut down Apple TV :D
    Inspired my mini Android PCs like a MK802 II what I want to finally get to is a USB memory sized stick that plugs into one of the USB ports on my TV to power it and at the other end is a HDMI socket. A HDMI cable goes from this to the TV. You'd simply select the HDMI input on your TV and stream.
    So it would require:
    USB for power
    HDMI out
    WiFi
    Processor able to hand audio and video streams using Airplay
    Some way of configuring it via an app or browser interface so you can get it on your Wifi network.
    So question is how do I get started, I have very little knowledge of building electronic projects.
    Looking for help to set me in the right direction.
  2. DickCappels
    Aug 21, 2008
    2,768
    669
    First, get copies of the following standards:
    USB -USB Implimenter's Forum
    HDMI -VESA (I think)
    WiFi - IEEE
    Then start reading.
    MatG likes this.
  3. mcgyvr
    Oct 15, 2009
    4,787
    974
    yeah that is NOT a simple project by any means.
    That is "expert" level for sure.
