Hi does anyone know where I could find information on modern aircraft communication systems?
C Thread Starter cheyenne Joined Dec 6, 2007 48 Mar 30, 2008 #1 Hi does anyone know where I could find information on modern aircraft communication systems?
K KMoffett Joined Dec 19, 2007 2,918 Mar 30, 2008 #2 The best search term is: avionics This actually relates to all avaition electronics. Google: communication avionics Ken
C Thread Starter cheyenne Joined Dec 6, 2007 48 Mar 30, 2008 #3 Will this cover communications with air traffic control also?
beenthere Joined Apr 20, 2004 15,819 Mar 30, 2008 #4 "Atc communications" brings up 203,000 hits on Google.
S Sreekesh Joined Jul 13, 2009 1 Aug 1, 2009 #5 i too searching to find the same thing on net. but no relevant circuits are found so far
J jpanhalt Joined Jan 18, 2008 11,087 Aug 1, 2009 #6 Welcome to the forum. Here is the fourth hit from a search for aircraft receiver: http://www.techlib.com/electronics/aircraft.htm You do not want to transmit on those frequencies without appropriate equipment and licenses. A moderator will probably move your post to its own thread. The other thread is quite old, and you are starting a new topic. John
