Air Ride Switchbox help
Status
Not open for further replies.
Niagara_V_Dub
Joined Feb 25, 2012
So I am trying to figure out how to wire this project up. Here are the details and links to the components.
I have 8 individual ASCO Valves that are 12v and .5amp as seen here http://bagriders.com/modlab/products/ASCO-BRASS-VALVES.html
Each corner has 2 valves (1 for up, 1 for down) and each corner I am going to use the switch seen here http://www.avsontheweb.com/product.php?productid=1308&cat=596&page=1 which is a momentary (on) off (on) switch with 6 prongs.
I want to have an all up / all down switch in the middle as seen here http://greatlakesskipper.com/produc...entary-onoffon-anchor-boat-rocker-switch.html
How would I go about doing this? Diodes? Relay? I know its possible cause its a common switch box function for yhe pre fabbed switchboxes... I just want to build something more custom and my own since I am an aviation electrician... but I have been out of the fleet for a few years as a recruiter and now forget how to do this.
Any help is greatly appreciated. If you could describe the method and then what values I would need for the components I would be forever in your debt. And I will take pictures of the build and finished project.
Niagara_V_Dub
Joined Feb 25, 2012
Also, forgot to add that IMO the tricky part is I want to be able to use each corner individually and have them tied into the all up / all down funtion. My worry is that hitting only the left front up switch it will trigger all up. I know there is a way... I am just to rusty to think of it.
williamj
Joined Sep 3, 2009
180
Niagre V Dub,
Assuming that I fully understand what you are looking for and that all switches can handle the solenoid loads, the attatched should be, atleast close to, what you are looking for.
williamj
dtrevino15
Joined Mar 26, 2024
now I KNOW I hit "go advanvanced' !!!
I know this is a very old post, but I am actually looking to answer this as well.
I dont really understand your answer williamj
So on my setup, I have 6 12 volt rocker momentary switches.
4 are used for up and down solenoids that allow each airbag to go up and down.
I want to use a 5th switch to activate the two solenoids in front, and a 6th switch to activate the two rear.
And if possible, a 7th switch to activate all 4 at the same time.
I can use a 6 pin switch for the front and back, keep the circuits separate, but didnt know if there was a way of wiring to use a 3 pin switch.
And how would the 7th switch work for all 4 circuits.
Don't know if this is possible, but any advice would be helpful.
Status
