Air Fuel ratio sensor LSU 4.9 sensor interfacing ( oxygen sensor )
Discussion in 'Automotive Electronics' started by Ali Raza_1441110966, Sep 1, 2015.
  1. Ali Raza_1441110966
    Sep 1, 2015
    air fuel ratio sensor used in cars, model LSU 4.9 boash , controller Chip CJ125 , i have searched alot, lots of info is also available but till now i am not able to understand its basic working principle of this sensor, because i want to use this sensor without the Controller chip, i want 0 to 5 volt output but CJ125 gives data in SPI format.
    also i am confused in functions of different pin out of this sensor.
    Kindly help
    ali
  2. shortbus
    Sep 30, 2009
    4,092
    1,671
    Google is your friend. www.bosch-motorsport.com/.../Lambda_Sensor_LSU_49_Datasheet_51.
  3. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    Why are you building one when you can buy a cheap china made one for next to nothing or spend the money and get autometer gauges.
  4. russian
    Member
    Sep 1, 2012
    55
    wide-band O2 sensors are not that trivial - you need an external controller with a processor to control it and decode the output. Cheap controllers start at about $50, those would provide you with analog 0-5 signal you are looking for.
