du u mind drawing that circuit for me, the whole circuit including the display. thankz
A Thread Starter aka-rato Joined May 11, 2012 58 Jun 13, 2012 #21 du u mind drawing that circuit for me, the whole circuit including the display. thankz
A Thread Starter aka-rato Joined May 11, 2012 58 Jun 15, 2012 #22 bertus said: Hello, You can reduce the voltage with a voltage divider to 0-2 volts. That can be fed into a 2 Volts panel meter to show the flow. Bertus Click to expand... Helo Can you please help me 2 draw the circut, i did try to draw a circuit but i nt working.
bertus Joined Apr 5, 2008 22,277 Jun 15, 2012 #23 Hello, The attenuator for the sensor to DVM consists of simply two resistors. The DVM will show the flowrate. Only the decimal point is on the wrong place (it will show a 10 times lower value). Bertus Attachments attenuator_for_sensor.png 5.4 KB Views: 22
