Again LED dimming and fading on
cmartinez
Joined Jan 17, 2007
8,257
What? Dimming LEDs? I thought we were working on a piano keyboard. :confused:
The ramp circuit is a response to what Martinez was searching for...ramps. See? It even has a piano key on the left side. :)
Anyway, a ramp is part of a pwm, and a ramp can end in a down ramp or a sudden stop. This being a piano, I expected a sudden stop unless one of the pedals is depressed. o_O
Yeah... I forgot to explain that in more detail.. my bad.. :oops:
What chillum wants is to build this circuit, which produces funny sounds when the light changes:
And wants to replace the optotransistors with opto-couplers, and he wants to ramp-up the leds inside optocouplers to produce the sounds he wants. That's why he needs to build a ramp up circuit first. Here's the source page.
cmartinez
Joined Jan 17, 2007
8,257
You are so getting ahead of yourself right now! The 4416 is merely my favorite jfet. It isn't right for this job. Look at how Martinez had to use a 100 uf capacitor to slow the ramp down.
But is the ramp up circuit the right approach to replace the optotransistors? Or should we go back to PWM?
Chillum
Joined Nov 13, 2014
546
I need 8 keys (optimally)... I don't know if I wanna afford it, if I go deep into my safe I might be able to afford the R30 one (R240)... maybe another way? if possible?
Chillum
Joined Nov 13, 2014
546
I finally got Mantech to quit showing me mosfets and jfet input op-amps. You have 4 jfets there and they are all horribly priced!
http://www.mantech.co.za/Stock.aspx?Query=n-channel jfetand
It must be tough living on the other end of the earth from the availability store!
http://www.mouser.com/Semiconductors/Discrete-Semiconductors/JFET/_/N-ax1rs?Keyword=n-channel jfet&FS=True
http://www.fort777.co.za/index.php?...h_result&search_in_description=1&keyword=jfet
My usually more expensive close by supplier: Yebo Electronics (www.fort777.co.za)
Have @R15.20 2N3819 - N Channel JFET http://www.fort777.co.za/index.php?main_page=product_info&cPath=269_456_605_663_664&products_id=5164
R5.27 BF245A N-Channel JFET http://www.fort777.co.za/index.php?main_page=product_info&cPath=269_456_605_663_667&products_id=5879
and then they have jfet op-amps
edit: they have only 1 item of the 2n3819 with 100 on order
and 619 of the BF245A
EDIT: mantech search with "n jfet" produces a higher amount of n channel jfet search results
http://www.mantech.co.za/ProductInfo.aspx?Item=340M0660 -- 2N4393 at R17.26
Joined Nov 30, 2010
18,224
OMG! What have you gotten me into?
I've been reading this for 45 minutes and have so many constraints logged into my mind. Un-availablilty of parts, money, understanding, transportation...
Meanwhile, my real life is demanding my time. I have a computer to fix today, and the owner is so slow she can't change lanes if she has a quarter of a mile to do it.
I don't think I can do this one.
cmartinez
Joined Jan 17, 2007
8,257
No problem my friend... I can take it from here... I'll see what I can do
Chillum
Joined Nov 13, 2014
546
*sigh* how will I? cmartinez, at the beginning you said "God-like" is incorrect, the correct word would be heroic!
#12
Joined Nov 30, 2010
18,224
There are several other ways to make a constant current source or a ramp. It's just that a jfet is so simple and adjustable. If jfets cost $4 and opamps cost $0.33 use opamps!
It's just that, The last time I bought 2N4416 jfets, I got a roll of 100 for $12.
Chillum
Joined Nov 13, 2014
546
I was wondering about the op-amps cause they ARE way cheaper --- if the result is the same?
#12
Joined Nov 30, 2010
18,224
Many ways to skin the cat.
Everything is simple...right after you know how.
Of course an opamp containing hundreds of transistors can replace a single jfet.
