Done that before and no damage to the fan. However, it does generate an ac voltage (about 2-3 volts at low current) and this can kill components in the mainboard or sometimes even the power supply. One thing I noticed is there is a 12V/5W fan installed and the service manual mentions it is connected to 15V. Probably for additional airflow. The fan is connected to the mainboard via a single clip connector and I can remove this during service. Must remember to put it back though - or it could overheat. The fan mostly cools the power supply along with the acquistion section.If you ever spin a fan up with air (as opposed to electricity) it is toast. Spinning a fan with air generates enough EMF to burn the innards out. Voice of experience. Stick a q tip stick in there to prevent spinning.
by Jake Hertz
by Duane Benson
by Jake Hertz
