Affordable Analog Mutiplexer IC
Discussion in 'The Projects Forum' started by iimagine, Dec 8, 2014.
  1. iimagine
    Thread Starter Active Member
    Dec 20, 2010
    129
    9
    I'm looking for an analog multiplexer IC that functions like the Harris HA-2400 but at an affordable/cheap price. Does anyone know of such IC?
  2. MrChips
    Oct 2, 2009
    12,656
    3,461
    What are your criteria? There are literally thousands to choose from.
  3. iimagine
    Dec 20, 2010
    129
    9
    basically i just wanted to be able to switch audio inputs using an MPU, what sort of criteria am i looking for?
  4. MrChips
    Oct 2, 2009
    12,656
    3,461
    For starters:
    1) Number of channels (x2 for stereo)
    2) Frequency range (20-20kHz assuming audio)
    3) Voltage range (±12V, for example)
    4) Serial or parallel control of channel select
    5) Package style, thru-hole DIP or SMT
  5. iimagine
    Dec 20, 2010
    129
    9
    1) Channels: >= 4
    2) Freq range: audio (20-20kHz)
    3) Voltage range: <= ±12V
    4) Serial
    5) Package style: thru-hole
    Thanks.
  6. Bernard
    Aug 7, 2008
    4,248
    424
    4066 except for +- 12V.
    iimagine likes this.
  7. Lestraveled
    May 19, 2014
    1,957
    1,218
    The HA-2400 is not just a multiplexer, it has four independent op-amps, one on each channel, and then a 1 of 4 selector. Do you not need the built in amplifiers that the HA-2400 has?
    If you just need an analog switch, then look at the DG441.
  8. iimagine
    Dec 20, 2010
    129
    9
    The built in amplifiers of the HA-2400 is a nice feature and I guess thats why it is expensive; I just need an analog switch with a built in decoder. Thanks for recommending the DG441
  9. crutschow
    Mar 14, 2008
    13,524
    3,392
    Why do you need such a high signal voltage?
  10. iimagine
    Dec 20, 2010
    129
    9
    I dont need a high signal voltage; I should have put VCC Voltage range <= ±12V; Signal voltages are just at line level;
    What I'm looking for is an audio signal selector IC/circuit (CD/TAPE...ect) that can be selected/switched from a Microprocessor
  11. GopherT
    Nov 23, 2012
    6,340
    4,094
    A simple old cd4066 should work just fine. About $0.30 each plus shipping.
  12. alfacliff
    Dec 13, 2013
    2,449
    428
    the 4066 is a quad bilateral switch, it has no decoder. the 4051 is a 1 of 8 multiplexer / demultiplexer that will switch line level signals wither direction with binary selection.
  13. Lestraveled
    May 19, 2014
    1,957
    1,218
    The OP wants a +- 12 volt part which the DG441 will do. The CD4066 and CD4051 will not support +-12 volts because they are single supply 15 volt(max) parts.
  14. GopherT
    Nov 23, 2012
    6,340
    4,094
    The OP said, less than 12 volts. And then cal airfield that he wanted line level audio in post 10.
    I stand corrected, 4066 is not correct. 4051 should work.
  15. Alec_t
    Sep 17, 2013
    5,980
    1,138
    A simple volts dropper/shifter could probably take care of that, cheaply.
  16. iimagine
    Dec 20, 2010
    129
    9
    Thank you everyone for your recommendations. The 4051 is a winner for me. I just ordered 10 PC for a total of $3.88 (shipping included!) Cant beat that.
  17. GopherT
    Nov 23, 2012
    6,340
    4,094
    Was that an eBay purchase or is there a US supplier with low shipping rates? Please let us know where you found those prices if not eBay.
    Cheers
  18. iimagine
    Dec 20, 2010
    129
    9
    It was an ebay purchase
