Affect of air gap in core
Discussion in 'The Projects Forum' started by denman_100, Nov 10, 2007.
  1. denman_100
    Oct 27, 2007
    13
    I have a custom wound transformer core that I found from some surplus store. I see that the secondary voltage is saturating when I hook it up. Will adding and air gap reduce those effects?
  2. recca02
    Apr 2, 2007
    1,211
    well cant say for sure but the general view is that it will help ,i think this is so since flux reduces as reluctance increases.
  3. mozikluv
    Jan 22, 2004
    1,437
    your question is quite vague. you didn't mention what is your primary and secondary voltage. the current that your secondary has to supply. the wire size you have used. the primary voltage frequency. maybe if you can suply this info then we can do something about it.
    moz
