ADXL375 offset register/Shock Threshold
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Mar 11, 2015.
  1. Vindhyachal Takniki
    Nov 3, 2014
    358
    6
    1. I have to write offset register values in adxl375.
    On putting device so that x = 0g , y = 0g & z = 1g
    I get output valuesfrom adxl375 as; xreg = -14 , yreg = 15 & zreg = +34
    Now what should I write to offset registers of adxl375;
    a). Is it invert of each value
    b). I read AN-1077 describing offset regsiter value of adxl345, it had mention values as
    X_CALIB = –(OUTPUT (X) ÷ 4)
    Y_CALIB = –(OUTPUT (Y) ÷ 4)
    Z_CALIB = –((OUTPUT (Z) – 256) ÷ 4)
    c). which of above I should choose
    2. I had to enable double/single threshold interrupt.
    I had read that this register is 780mg/LSB.
    Also datasheet says:
    "The SHOCK_AXES register specifies the participation of each of the three axes in single shock/double shock detection."
    How does it correlates to values in THRESH_SHOCK register.
    Is it
    THRESH_SHOCK = sqrt( (dataX * dataX) + (dataX * dataX) + (dataZ * dataZ) )
