ADXL330 output signal in Simulink
Discussion in 'The Projects Forum' started by legolasx, Mar 31, 2011.
  1. legolasx
    Aug 5, 2010
    Hi i'm having a problem in logging signal for an analog accelerometer,ADXL330. i obtained a sinusoidal signal from the simulink environment, which is not the desired output signal (voltage) i wanted, yet the voltage i measured at the physical terminal has a constant output (desired). any1 can help me in this, i'm using a Advantech DAQ card.
