I am building a dc power supply and have a few questions about perfboards and connectors.
1) For a transformer is it best to solder the wires to the primary and secondary lugs as I was using a mini female spade. Is there another connector better than the female spade?
2) The perfboards I use have a very small diameter hole and copper around it and I physically can't put in some thick leaded components like power diodes and the FWB I am using. Is there a wider holed perfboard available or is there a certain connector I can use. I was thinking a terminal block but surely there is a better alternative.
Eventually I will make an etched through hole pcb for it
