Hello everyone, i'm new here and i don't realy know if this is the right place to post this, but still, here it is.
I've been working on a 8(4)-step sequencer based on two 555 and one 4017 IC, and i've ran into a problem. The idea is that on every step of 4017 IC, the second 555 (so called "sound generator") produces a different sound, which is manualy adjusted by 8 potentiometers, attached on each output pin of 4017. The problem is that i don't know how to design the actual connection between those 8 outputs in a way that would create 8 adjustable and independent sounds. I've experimented with basic NPN transistors and few additional resistors, but without any major success.
Any advice is highly appreciated.
