Advice with replacing a schematic input voltage
Discussion in 'General Electronics Chat' started by doby, Jun 28, 2015.
  1. doby
    Thread Starter Active Member
    Aug 17, 2011
    43
    I want to use a schematic that is designed to run on 12V, if I were to change this to 4.5V what alterations would I need to make to the circuit?
    I presume the resistors would need changing, is this just an ohms law calculation? What else would need changing?
    (Schematic attached)
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    You wouldn't be able to run 3 LEDs in series. Depending on the forward voltage, you might have to run them all in parallel with their own current limiting resistor.
  3. doby
    Aug 17, 2011
    43
    Yeh I don't intend to, I should have said that, sorry. That side of things I can make sense of anyway, it's everything else I need help with!
  4. dl324
    Mar 30, 2015
    3,376
    651
    The only other thing to worry about is the threshold voltage of the MOSFET; it needs to be low enough that it turns on completely at the lower voltage.
