Hello everyone.
I'm working on something that needs to be powered at 35VAC (1.5A max) using a Lithium 4400mAh battery (3,7VDC). I've been searching and testing some DC/AC inverter circuits (using 555 timers, couple of mosfets, some reused transformers...) with little success, and i was wondering if what i'm trying to achieve is even possible. If it is, what would be the best approach? or, how would you solve this?
Is there some kind of IC that can do the job, similar to a MIC4826 EL driver (but with a bit more of current output, of course)? I don't think so, but well, i have to ask.
Thanks a lot, any help would be much appreciated, if you need more information just ask.
