Advice Request: Linux USB Control of Digital IO
Discussion in 'The Projects Forum' started by GettingOld, Feb 28, 2011.
  1. GettingOld
    Feb 28, 2011
    Simple problem. I need to control a IO from Linux over a USB interface.
    I was going to use a MSP430 Launch pad, but the CDC serial support with Linux is not reliable. I am planning on using a TI RF2500 with the built-in application UART next but it is a little pricey ~$50.00.
    The goal is to control a digital relay which will in turn be used to power cycle an unreliable piece of low-voltage equipment.
    I need nothing more than to be able to assert an IO, wait for a bit, and then send a character back to the host application.
    I'd appreciate any pointers to low-cost, readily available solutions. I'm in Canada, so things I can get from Digikey would get preference.
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
