Advice on LED Direction
Discussion in 'The Projects Forum' started by Jkuehn, Feb 28, 2014.
  1. Jkuehn
    Feb 28, 2014
    First off, this is the best forum out there!
    I have a project I doing that I'm doing requires 20 LED (5050, 6pins). I'm running this off of two 3v batteries = 6v. My question is this, what is the best way to do this series or parallel? Also I've been having troubles figuring out the number of resistors and size to be used. Any help would be greatly appreciated. Thanks
  2. bertz
    Member
    Nov 11, 2013
    239
    32
    In order to calculate the value of the resistors, you need to know what is the forward voltage drop, check the data sheet for this info. What is a 3 volt battery? Are you using LIFE, LIPO, alkaline or rechargeable? What is the mAh rating of the battery?
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    With only 6V.. chances are you can at best do 10 parallel strings of 2 in series on each string and you will need a resistor for each series string.
  4. bertz
    Member
    Nov 11, 2013
    239
    32
    Like this:
