I have one circuit ( 12V battery operated) that drives about 60 LED's.
The LED's have about 2V voltage drop, so I use 5 in series and limit the current to 20ma. That gives me a total current of 240mA.
The battery is charged by a solar panel. I must reduce the power needs, so the solar panel be as small as possible (because they are expensive). currently we use 20W panels, but I must find a solution to use 10W or less.
The Leds are on 500ms and off 500mS.
The battery and solar panel must be 12V.
Can someone give me an ideia / orientation. This 1st solution that came in mind is using a step up regulator and power the LEDs with 24V and using 10 in series (Total current will be half).
Another is using a capacitor to store energy, cut the power, discharg to the Leds and connect the power again to another cycle. (a little like a flash). Is that possible ?
Thanks for any help/advice.
JB
JB
